Many version, only one byte different. DVP5990K_55 , DVP5990K_75 , DVP5990/37(37b) , DVP5992/37(37b)
*new skins *new OSD font (text and graphic) *new filebrowser (with scrollbars, outlined font, new icons) *40 cahr for filelist, 44 char for DirList *3 Mp3 TAG in filebrowser *fix "Kbps" bug. *JPeg preview small size at bottom of file list
*move volume from bottom to a higher position.
*Patch "Title" as "GoTo" *Auto-load subtitles
*Patch subtitle area and subtitle window *Patch subtitle color scheme (use normal fonts) *fix "1 sec. srt. bug" *4 fonts for subtitle (Standard, Small, Medium and Large)
*DVD Quick Play. I replace VOD menu (from general page) with new, named "DVD-Video" with two option "With menu" and "Without menu".
*WordWrap + Reformat *UnicodToCP 1252 (to see special characters in filebrowser)
Two version for each firmware with white and yellow subtitle
Hi, Traian! Do you know what is that one byte difference? In which routine is it?
Thanks!
♫ But now the damage's done and we're back out on the run ♫ ♫ Funny how ev'rything was roses when we held on to the guns ♫ ♫ Just because you're winnin' don't mean you're the lucky ones ♫
Thanks!
Yes, see last 8 bytes in firmware.Normal last 4 bytes are for checksum, but this firmware have "Extrablock". 5990_37 last 8 bytes 00 00 00 00 00 00 00 00 5990K_55 00 00 00 05 00 00 00 05 5990K_75 00 00 00 04 00 00 00 04
I think this bytes are used for change Root Menu. But I don't know where are used in cod or how are used...
Is there a way to change subtitle size? I see there are 4 fonts for subtitles, but I don´t know how to change them. I searched in the forum but didn´t find an answer. I´m using yellow subtitles and it´s very good, do you think a black outline would be nice? Thanks!
Subtitles fonts are in "DivX Subtitle" in "Preference Page" , but this menu is active only in FileBrowser.
Black outline ?(!!!), subtitles are with black outline, if you want OSD with black outline, the answer is no (for this time...).
Thanks, now I found the menu! I don´t know what happened, but the subtitle was yellow without black outline, but today, after using the "DivX subtitle" menu the subtitles are perfect, with black outline.
I don´t think this firmware will need more than 1 version! It´s already great! Unless if we could use MKV and H264 from an external HDD to see HD and FullHD movies! But I have already ordered my Popcorn Hour A-110!
Hi gaucho, I don´t think you can use MKV, unless you use specific media players to decode H264. Search for Popcorn Hour or TVix, these can handle HD and FullHD.
Hi vb6rocod, Bad luck, my DVP5990K55 was freezing when watching DivX, from USB or loader. I tried many times, had no success, and took to the store I bought, where they changed to a new one. With my new 5990, I tried and worked nice with factory defaults. Then I upgraded the firmware to the yellow version, and again, the subtitles showed in yellow but a thin font and no outline. I entered the menu, changed the subtitles from default to small and confirmed, changed back to default and tried my DivX. Now everything works fine! Thanks again!
Friends, in special to the desenvolvetor… I postei this in the HtForum Brazil
Only as curiosity… Looking under of player people view an adhesive with the following information: " Reproductor of DVD Mod. DVP5990/55 110-240V-50-60Hz 12W IMPORTER: PHILIPS C.V MEXICANA, S.A. AV. THERE PALM IN. THE 6. COL. SAN FERNANDO THERE HERRADURA HUIXQUILUCAN, EDO. OF MEXICO, CP.52784, TEL-52 69 90 00 PHILIPS PERUANA S.A - RUC 20.100.102.090 aV.LARCO, 1301 - 4 FLOOR, MIRAFLORES - RASP PHILIPS CHILENA S.A - RUT 90.761000.4 AV. STA MARIA, O760 - STEP - SANTIAGO PHILIPS OF AMAZÔNIA IND. EL.LTDA - CNPJ 04.182.861/0025-66 PHILIPS ARGENTINA S.A VEDIA, 3892 (C-1430 DAL) CIUDAD OF BUENOS AIRES PHILIPS CARIBBEAN PANAMA BUILDING EVERGREEN (PISO), AV. STA B SUR Y SILENCES 78 THIS P.O. BOX 87-3941. PANAMA7, REP.DE.PA NAMA EXDPORTADOR. PHILIPS ELETRONICS HK LTD ORIGIN PARENTS: CHINA - Considering that a colleague of the forum told here that Philips said not yet that was commercializing this DVD to player here in Brazil, - Considering that after much search I evidenced that is very difficult to find it: It concludes: It seems to be a direct importation to the Philips manufacturer of China for some great South American wholesalers… but assumption is alone mine… nothing concrete. For opportune I am testing some things of it: 1 - External legends in DivX> > deep ash and white letters… tsc, tsc, tsc, that coarse standard of Philips… too bad! But I lowered one firmware in the site of great jmaraujo as it already had postado in this topic that a desenvolper of the Romania already had one firmware alternative correcting this, I goes to see eats was. 2 - Player wheel WMV in a good one, I tested way pendrive! But I only could test with those WMV of the Internet (low quality) later I go to try with better WMV. 3 - Background of Philips is very without favour! Already I photographed here and later rank. Friends, I do not go to promise to none review of player, therefore I do not have ability for this, but I have some material to test and in the possible measure do I go post the results, ok? I am photographing setup, legends DivX etc… After examining well and registering firmware original, I go to install firmware of the desenvoloper vb6rocod of the site of jmaraujo and to see the modifications done. The coletânea of comparative photos I dispatched by post first back in the site of jmaraujo and later here, ok? The reason of this is that I find the opinion of the desenvolper basic, before any another conclusion agrees? Abraços
Philips offers in its site an update for the DVP5990 . I made download and I compared background with the one of vb6rocod. I found well better of vb6rocod ! Tomorrow I go to install firmware and I will see, really, the differences. Background Philips:
New version:DVP5990_vb6_v1_2 (5990/37, 5990K_55, 5990K_75)
New "File Cutter", number of character in FileBrowser is limit now to length of "yellow" band.(More than 40 char.) New font for FileBrowser. Here is a picture (from other player, but you can see new font and new file cutter)
Move DVD-Video (DVD Quick Play) to "Preference Page" ,where is now "DivX Subtitles" Move "DivX Subtitles" to "General Page", you can change font and color of subtitles when movie play. Add a new menu for subtitles color. New menu is "Color" with option "Default" - white subtitles and "Cool" - yellow subtitles. New menu is after "DivX Subtitles". Change color for "Display" "Folder/Single/Repeat" to white,now is visible. "More" white color for some OSD message. After update,apply a "Reset" and change font and color (for subtitle) to "activate" change.
vb6rocod: Thank you very much. Your last firmware for DVD5990K is, in one word, Wonderfull! I have a DVP5990K-55 with your version DVP5990_vb6_v1_2 for 3 days now and I want to say: One of the very best DIVX players already. flawless operation. at this time, no bug detected. If you need, I'm inclined to test and report every new version.
Thanks for the firmware. It's almost perfect. I want make a request: Pelase, in your next firmware include a GOTO function for files avi/divx. Thanks!!
What you say?
Already has GoTo... Press "Title" two times and you will see "GoTo:-:--:--". Enter "h:mm:ss" and GO!
I'm sorry for the stupid request. I didn't see the information in your post. I was tried with the button "Display" (for DVD, there is GoTo in that button). Then your firmware is perfect!! Sorry for the bad english! Thanks!!
congratulations, even better now. My question is if the 40 caracteres file browser apply to USB also? thank you
From USB only 23 character, but you must be happy, most players display only 8 (in fact 6, last 2 are like ~1). And in my firmware is no limit to 40 (for files from CD/DVD).
Usuarios navegando este foro: No hay usuarios registrados visitando el foro y 1 invitado
No puedes abrir nuevos tópicos en este foro No puedes responder a tópicos en este foro No puedes editar tus posts en este foro No puedes borrar tus posts en este foro No puedes enviar adjuntos en este foro
